New to me Strada
Papa Lazarou
Re: New to me Strada
Post by Papa Lazarou »
Ming wrote:
MickeyMoto wrote:...Alarm bells ringing... have you rechecked cam and ignition timing?
Maybe the key is sheared or missing so that the flywheel is not correctly positioned?
The Woodruff key is nearly flat, although it shouldn't shift much as it's torqued to spec.
Papa Lazarou
Well, the Guzzi is very happy. Once I've done the chores I'll take it out.
Papa Lazarou
Rob at Revs suggests lapping the end of the crank with valve paste. I'll do that.
I will also take the flywheel off, check for pinched wires on the stator and knock out the old Woodruff key. I can then properly position the flywheel. I will also check that all the marks line up-I understand the cam belt has been replaced so this is necessary.
If anybody knows what size Woodruff key it is, please let me know.
Incorrect fitting of the belt shouldn't affect the TDC marks, but well worth checking. Perhaps the drive pinion has been disturbed at some time? I have happy memories of someone making a woodruff key out of an old bicycle spanner on a camp site in Sulby Glen during TT week (err, um 1973). It needed to be 'stepped' as the slot in the alternator rotor had worn loose (AJS 500 single). All done with a junior hacksaw and file, with the spanner nailed to a log as a vice for the first cut, then heat-treated using the camp fire and possibly quenched in beer - happy days :)
The parts list states key "3 x 5 R=6,5". If that's any help. 3mm wide by 6mm long radius 6.5 mm?
Gilera: 1957 175 Sport
Honda: 1984 CB250RS
Wishlist: 2026 Morini 350
Papa Lazarou
Ta. Very useful.
There is also the worry as to why this bike was laid up in the first place.
73? I think I was still riding a POS Tiger Cub. Awful thing.
1973? Was still in shorts. What's an AJS? :)
Papa Lazarou
go on. what's an AJS?
Coxey
Post by Coxey »
All
Junk &
Scrap ! :D
___________________________________________________
1989 Kanguro X3
BMW K100RS
Bah! Modern yoof. A.J.Stevens of Wolverhampton. You'll be telling me you've never heard of an AJS 7R 350, 500 'Porcupine' TT race bike or 250 2T (Villiers derived) Stormer 'scrambler' next ;) By the time I had one they were part of AMC (Associated Motor Cycles) with Matchless and Norton. Even you youngsters must know about Norton!
Honda: 1984 CB250RS
Papa Lazarou
72degrees wrote:Bah! Modern yoof. A.J.Stevens of Wolverhampton. You'll be telling me you've never heard of an AJS 7R 350, 500 'Porcupine' TT race bike or 250 2T (Villiers derived) Stormer 'scrambler' next ;) By the time I had one they were part of AMC (Associated Motor Cycles) with Matchless and Norton. Even you youngsters must know about Norton!
I loved my Nortons. My last one was an Atlas. I balanced the crank, gas flowed the head and it was timed at 124MPH. Not bad for a 1964 bike. Very little vibration, after the work I did. Had to sell it because of money problems. Wish I still had it.
Papa Lazarou wrote: I loved my Nortons. My last one was an Atlas. I balanced the crank, gas flowed the head and it was timed at 124MPH. Not bad for a 1964 bike. Very little vibration, after the work I did. Had to sell it because of money problems. Wish I still had it.
An old mate of mine has a Matchless with the AMC 750 engine converted to 270 degree crank. All machined himself. Can't say I miss my 1962 650 31 CSR that much. The definition of vibration.
Honda: 1984 CB250RS
Coxey
Post by Coxey »
Only kidding. The Model 8 I had when I was 18 was brilliant. It cruised all day at 50 and thumped out a glorious noise to boot.
8)
1989 Kanguro X3
BMW K100RS
I prefer more modern makes like Triumph, Moto Guzzi MV Agusta and Morini against those old 1950s and 60s long gone manufacturers! :)
Papa Lazarou
repeat post
Papa Lazarou
Aaargh. The worn flat Woodruff key won't come out. The seller was well aware of this problem it appears-hence the slipping flywheel.
I've drilled it gently and tapped it with a drill (gently!). I've used WD40 on it. It needs heart.
So, I've removed all the bits back to the crank and now need to remove the cam belt-which is very, very tight.
I suppose I should just use valve paste on the end of the crank and lap the flywheel in tight.
The seller has not responded.
