Page 1 of 2
Kanguro X, what battery?
Posted: 06 Oct 2010 07:39
by OogieBoogie
Hi early Kanguro owners,
I was silly enough to throw away the dead battery from my Kanguro when I took it off the road, now I'm not sure which 6v battery it takes. This is critical because the size of the battery box moulding in the inner sidepanel is just big enough for the battery so the next size up probably won't fit there.
can anyone help?
Re: Kanguro X, what battery?
Posted: 06 Oct 2010 14:27
by robinh44
Most online guide claim a 12v battery, but the Yuasa reference is a 6N2-2A. This looks reliable as it also refers to the old 500 enduro or early camel that took a 6v battery. Hope you get one sorted.
Robin
Posted: 06 Oct 2010 19:14
by OogieBoogie
Robin, did you convert your special to 12v battery? Do you know if it requires a different reg rec to convert?
I'm thinking there must be some pretty small dry 12v rechargable batteries available these days maybe I'll find something small enough to fit the Kanguro battery box.
Posted: 06 Oct 2010 20:12
by robinh44
Yes I did, you can convert to 12v by rewiring the stator plate coils, but you will need to change the reg/rec to a 12v one. I initially used a modern (indian made) royal enfield regulator/rectifier, it was ok but the regulator did not seem to good so I went to one made by MZ-B.
There is a link below to the article on the Morini NL club page detailing how to convert to 12v:-
http://www.motomoriniclub.nl/6-Volt-conversion.pdf
If you are ok with soldering it is a good conversion, and as you say you should have a wider choice of batteries. Remember also to change indicator, tail, stop and instrument bulbs to 12v! as I think only the headlamp runs on 12v under the 6v/12v system.
Robin
Posted: 07 Oct 2010 06:51
by OogieBoogie
Robin,
Thanks for the info, I'll look into converting to 12V.
Stu.
Posted: 08 Oct 2010 22:19
by kangurada
A Boyer Brandsen Powerbox is the solution on my Kanguro X and provides 12v electrics. The manufacturer's link is
http://www.boyerbransden.com/pdf/Power_Box_Leaflet.pdf. I'll have a look tomorrow at the battery type and see if I can put a picture up. It's a neat setup.
Posted: 09 Oct 2010 10:56
by kangurada
Here's pictures of the PowerBox installed with a 'massive' 3Ah 12v battery. No need for complicated stator rewinds, just put bullet connectors on the end of the stator leads, connect up, and junk the rectifier. A snug fit, but a fit all the same.
Posted: 12 Oct 2010 20:20
by alan j
Some good "info" here! 12 volt conversion is a good idea as the 6volt system is a bit feeble!-the headlamp bulb, as everyone knows is12 volt and is powered directly!-a very strange mixed system! The original battery is the same as a Honda Melody-but they are now all made in China and rubbish! I have fitted one of those small round 3-cell types-will just fit the space and stay up well if you don't use the bike regularly.
Posted: 13 Oct 2010 09:44
by stillooking
Hi, I'm just looking at this thread out of curiosity and wonder whether it could be applied to my 350 sport- of course there's much discussion about ignition/charging etc about the 350's as well.
In this instance, what I can't understand is, why can't you run the Kanguro without a battery, my understanding is that the BoyerBransden power box can act as a capacitor, so why do you need one (a battery)? Do you need it to run certain equpt ?
Posted: 13 Oct 2010 21:55
by kangurada
The answer to your first question is yes. I obtained the bike with a blown engine (main bearing) and simply put in the engine from my fire-damaged Strada. So the PowerBox will accept 12v from the stator as well as 6v.
I haven't tried disconnecting the battery but I guess that at low revs the lights are liable to flicker, and of course not work at all if the engine isn't running (which you might want e.g. sidelight on for parking on a dark road, or taking out of garage at night).
Posted: 14 Oct 2010 09:29
by stillooking
Thanks Kangurada for your reply. That clarifies it for me...ah, so you're running a Strada engine in your Kanguro.
Can I ask have you left the coils/transducer thingy's as standard? If you had/have the std. electronic tachometer fitted would this have any effect? I guess not? As you can probably tell, I struggle with electrics...
You're right about when bikes are fitted with 'capacitor systems' - on Youtube there's a few examples of chopper lads with them fitted and at low revs the lights do flicker, but when they get going they are fine.
Posted: 14 Oct 2010 18:20
by kangurada
As the Strada engine has the red pickup I used the black Strada transducers. The Kanguro had the black pickup and grey transducers, and they can't be mixed and matched. The Strada revcounter worked, but its glass was too smoke damaged and it's needle bent by the heat to be much use, so I'm doing without. The Kanguro revcounter is of course gear-driven rather than electronic, and the Strada cam isn't machined to accept the drive end of the cable!
Posted: 14 Oct 2010 18:54
by stillooking
ah ha! I didn't know the Kanguro had a gear driven tacho - thanks
Posted: 16 Oct 2010 18:38
by OogieBoogie
Robin and Mikey,
Thanks for the advice (and parts!), I decided to go with the standard electrics for now.
Today I replaced the battery, swapped the petrol tap from my old tank to the new one, put tank, seat and silencer on, added some pertrol, kicked it over a couple of times with the ignition off. Switched on the ignition and bingo! it fired up first kick after 3 years in the shed.
It not only started, but is running very sweetly after I stripped and cleaned the carbs.
It's not all good news though, there's some problem with the wiring still, when I put the headlights on the LH indicators lit up too (not flashing), the headlamp was vey dim seems the 12 lighting circuit is leaking to the 6v system.
Didn't get started on that one yet, changed the oil and cleaned the chain instead. I need to get hold of a wiring diagram to sort the lectrics out.
Stu.
Posted: 16 Oct 2010 18:49
by robinh44
Stu,
Below is link to kanguro owners manual from 1984, there is a wiring diagram on the back page:-
http://www.mediafire.com/file/3c4q8g8sc ... uro_84.pdf
Also attached link to general Morini maintenance manual, useful for engine and general maintenance:-
http://www.mediafire.com/file/9lsghnlmx ... manual.pdf
Regarding you electrical problems it might be worth checking the earth points on the indicators and also the control switches for the indicators and headlamp. Also check all spade connectors. Let me know if I can help anymore.
ps hope the silencer was ok, does it sound good?
Robin
