cam belt sizing
joseb42
cam belt sizing
Post by joseb42 »
Virtualy every comercially available, including Mdina Italia, 124L075 cam belt I can find is a metric equivalent ie nominally 314.33mm.
That is with the exception of MEDWAY with a true 12.4 inches ie 314.96mm
huub
Re: cam belt sizing
Post by huub »
as far is i know the 124 is the number of teeth on the belt ,
not the length in tenth of inches.
AntietamClassicCycle
Re: cam belt sizing
huub wrote: 18 May 2022 09:00 as far is i know the 124 is the number of teeth on the belt ,
124 is the "outer circle" measurement, there are 33 teeth.
Re: cam belt sizing
124L075 is the identificacion of the right belt. The Optibelt ones use to cost less than 10 €.
As they are industrial belts they are not measured but uce to fit. I´ve allways used them on B camshaft pinions without problems.
