Size of clutch nut
Posted: 25 Aug 2008 20:51
Have reached the point where I can undo the clutch nut (got past the broken stud without too much bother). I have measured across the flats of the nut and make it 25mm. I don't have a 25mm socket so have been looking in all the local car parts shops. Can I find one at 25mm? Can I b***ery! Is there such a thing readily available? I have bought a 1 inch (25.4mm) socket which feels slightly loose - I think it will be ok to loosen the nut but am not sure if I ought to use it to refit the nut - don't want to risk rounding the nut or not fixing it tight enough. What does everyone else use?
