New owner 500/6
Posted: 25 Jul 2016 19:15
by kainsworth
Hi, I have just bought Jaydubs 500 Sport, I have fitted a NOS tank from NLM and now the leaks / bits in the tank have gone away. I do however have a question about the front brakes, between the top caliper fork mount and caliper is a think washer, this means the side of the caliper slot is oh so close to the disk, is this normal??
I had one of these new in 1984 from Jack Lilley and foolishly sold it, many years later the plan is to restore and ride or ride and restore, I cant remember the reg of my old one but there cant be too many B reg ones out there
Kevin
Re: New owner 500/6
Posted: 25 Jul 2016 20:38
by corsaro chris
Hi Kevin, and welcome to the Forum - hope that you've joined the Club as well!
Common advice is always ride and restore - it's more fun and summers here!
Good riding,
Re: New owner 500/6
Posted: 28 Jul 2016 16:53
by Steve Brown
kainsworth wrote: between the top caliper fork mount and caliper is a think washer, this means the side of the caliper slot is oh so close to the disk, is this normal??
Kevin
Hi Kevin and welcome. There should be a a spacer there about 3 or 4 mm thick, rather than a washer. Maybe someone lost the original and substituted washers? Not difficult to make or I bet NLM have dozens on their shelves. I can measure one tomorrow for you if you like?
Re: New owner 500/6
Posted: 30 Jul 2016 10:50
by kainsworth
Hi that sound like what I have I will have a play and try and equalise the slo, currently the caliper rubs on the disk at one point! Hopefully MOT soon..................
Re: New owner 500/6
Posted: 31 Jul 2016 14:03
by kainsworth
Problem identified....... the wheel is sitting 1mm ish to the riders right!!!! hence rubbing on each caliper, have taken it apart and reassembled and a bit better, sent for the manual from NLM to check the set up but it seems throttle side just the speedo drive, clutch side a stepped spacer, so although I do not now how, I now know why
Re: New owner 500/6
Posted: 18 Sep 2016 17:35
by kainsworth
Now with added first pass MOT...............
