Clutch Cover
Posted: 23 Jul 2014 10:05
by Dom
I'm recommissioning a 500 Strada that I've owned for nearly 20 years but not used for the last 5. The kickstart isn't disengaging properly, so set about digging it out to diagnose/address, but I cannot figure out/remember how to crack the left hand side engine cover off. All visible bolts, roter, clutch etc have been removed, but it's stuck fast. Do I have to pull the oil seals out? (if so, presumably new replacements will be in order), or is there a knack?
Any advice or guidance much appreciated.
Dom
Re: Clutch Cover
Posted: 23 Jul 2014 20:57
by Dom
Panic over. Inspired by Mr Comptons Youtube contributions, a sharp tap, several actually, did the job. Naturally the kick start mechanism exploded all over the floor, but all looks perfect. Next question; why does the freewheel mechanism not disengage properly? (clattering when engine runs) :?
Re: Clutch Cover
Posted: 24 Jul 2014 11:50
by EVguru
You probably had the lever set in the wrong position.
