I’ve solved my clutch spacer issue.
Next issue is!
Is it normal for the left side engine cover ( not crankcase) to needing to be pulled down the last 2-3 mm with the screws to compress the neoprene ‘sleeve’ (part no. 23.02.18 pump junction ring in parts book) by between oil pump discharge and oil gallery intake in that cover?
Oil Pump “pump junction ring”
- George 350
Re: Oil Pump “pump junction ring”
Yes. Original neoprene bit had a conical face towards the cover, more recent ones are straight. Conical needed around 1mm 'compression', newer type nearer 2mm.
Phew, thanks George, that’s a relief! Seems I’m on the right track.George 350 wrote: ↑22 Aug 2025 09:13 Yes. Original neoprene bit had a conical face towards the cover, more recent ones are straight. Conical needed around 1mm 'compression', newer type nearer 2mm.
