Flywheel Cover Swap
Flywheel Cover Swap
Hello, New to the forum and so far most issues that I have had issues with have been helped with the search button going through past posts. My 1980 500 Sport has had a bent starter drum ever since I have had it. Probably someone trying to pull the flywheel at some point with a gear puller. I just got around to removing the drum from the flywheel and there is a lot of space under the cover now, like I could store tools or small or luggage under there. So my question is are the E starter covers interchangeable with the Non- E starter covers without swapping out the 500 flywheel. They look less bulky in pics.Thanks in advance, Lance
Re: Flywheel Cover Swap
Yes they are ! and a lot lighter too...
Thank you for the response, I'll begin my search
