extra key blank
extra key blank
Does anyone know where to buy a key blank....I took my key to a locksmith and he laughs...He says he needs a blank to copy this key?? any suggestions. Thanks
I had to photocopy all of my Morini keys (ignition, petrol cap, seat lock and steering lock) and write the numbers stamped on them under each copy so the locksmith could get blanks. Then went back a week later and had the blanks cut from the originals.
I once spent a month looking all over the house for the original keys only to find them in my motorcyle jacket pocket where I had looked several times before.
Key Blanks
I was in NLM yesterday and they have blanks available.
key blanks
thanks for all of the advice...where is nlm?
NLM
NLM North Leicester Motorcycles; located in England they send stuff all over the world in support of Morinis.
www.northleicestermotorcycles.com
Hope that helps
Andrew
Hope that helps
Andrew
Just had a spare key cut for my Kanguro (CEV type key). I needed a slightly longer key to clear the Trailtech Vapor speedo I have fitted and my local key cutting/ shoe repair shop was able to use an Alfa Romeo blank and produce a perfectly working key, about 10-15mm longer than standard. Might be handy to remember in an emergency.
Robin
Robin
key
thanks for all of the advice!!
