WANTED: left foot gear change conversion for 350/500 strada
Hi does any one out there have the necessary components (links etc) to convert from right to left hand gearchange for 350/500 strada? or has anyone found a different method to change it..
Many thanks ....
Many thanks ....
I have thought about adapting the change over linkages from the later off road models or perhaps removing the centre stand and using the centre stand bolt holes as a way to support the change over linkage.
I really dislike the right foot gear change and all of the above was planned for my race Morini. I really believe that I could have gained valuable seconds with a left foot gear change. The race bike is a dormant project at the moment, but maybe one day I'll get around to doing this conversion.
H.
H.
- Contact:
There are no specific kits/linkages available so you are on your own; you could use some bits from later off roaders etc but you will need to mod the frame and you would end up with off road type levers, not quite so delicate or dainty to look at. To me it always seems a lot of work for very little but then I swopped between my kanguru and strada when they were both working with no difficulty.
euh ???SupermotoDave wrote:There are no specific kits/linkages available so you are on your own; you could use some bits from later off roaders etc but you will need to mod the frame and you would end up with off road type levers, not quite so delicate or dainty to look at. To me it always seems a lot of work for very little but then I swopped between my kanguru and strada when they were both working with no difficulty.
There are kits for 350 's.
Sometimes you'll find them on the German ebay.
I have seen 2 sets (in 3 months) selling around 20-25€
- Contact:
