Morini 500W Stator Wanted
Canuck750
Post by Canuck750 »
Looking for a good Stator for a 1979 500W, also a regular/ rectifier if available.
hombre
Re: Morini 500W Stator Wanted
Post by hombre »
I probably have one from an Excalibur + the regulator. I won't be home (in NL) before the 20th of september though
Canuck750
Post by Canuck750 »
no problem, as long as it fits my 1979 500W I would be happy to purchase them!
I am in Canada
Jim
hombre
Post by hombre »
it should, it has the same setup as the 500's. We'll be in touch later
Canuck750
Post by Canuck750 »
The reg/rec and stator arrived yesterday, looks good thank you!
Do you by chance have a wiring diagram for the Excalibur 500? I can't access the club technical section to look up wiring diagrams for some reason
(I have contacted the administrator).
Just want to be sure I hook up the reg/rec properly.
Terminals on the Reg/rec are G G +B C
I know the two yellow wires from the stator go to the G - G terminals on the reg/rec and the green wire from the stator goes to the fuse box for connection to coils.
The red wire from the stator goes to ?
The +B on the reg/rec I think goes to brown on fuse box (ignition switch power on)
Jim
hombre
Post by hombre »
Good to know it arrived!
I have uploaded a pdf of the Excalibur manual here: https://docdro.id/kjjL8Oi
Don't know for how long it will be there, I can send it by mail as well.
Canuck750
Post by Canuck750 »
That is great! thanks again
Jim
