Morini 501 front wheel brake disc
Hi anyone got a replacement front disc for 501 camel or know if there is an alternative manufacturer?
Re: Morini 501 front wheel brake disc
Hello Iv4n,
i have received information from a colleague in the ital-web.de forum that on the 501/2 Camel the front brake disc of the Sachs Roadster should fit:
Sachs Roadster 125 V2
year of construction: 1998-2002
outside 260 mm, inside 105 mm, thickness 4mm
But please check yourself.
Greetings
Markus
Greetings
Markus
I replaced a disc on a Dart using one from a Yamaha TDM. It was a Grimeca disc. I believe Grime ca made components for Italian manufactured Japanese bikes. May be worth a look at their catalogue.
Have you tried mdinaitalia? would this fit https://www.mdinaitalia.co.uk/front-brake-disc-260.html
