Flowerpot
Flowerpot
Has anyone got an air filter flowerpot going spare? I wish to test if this will make any difference with some fuelling problems. There seems to be more to these 507’s fuelling than one cares to experience. Not to mention flexible couplings......
Re: Flowerpot
Hi John. I have a flowerpot from a Kanguro spare. Not sure if the dimensions are the same though? If you are going to Shepton Mallet show I could bring it with me.
Re: Flowerpot
Hi Steve
That is kind of you, am going on Saturday. I shall be the one with grey hair and a beard. I will pm you....
Re: Flowerpot
The diameter of the manifold towards the air filter is different with the 25 and 28 Dellortos. PHBH 26 and 28 are the same diameter towards airfilter.
Re: Flowerpot
So if I understand you correctly, the outer airbox diameter are of a larger diameter for the PHBH equipped bikes? No doubt easy to see but more difficult to describe. I am prepared to be illuminated.
Thanks for the help. John
Re: Flowerpot
The part (tube) of the carburator where you put on the filter has a firferent diameter. PHBH 28 is 42 mm if I remember it well, VHBZ 25 is smaller . So a flotpower for a VHBZ 25 will not fit a PHBH 28
Re: Flowerpot
Thanks I understand it now. I should remind myself to measure everything, no matter how trivial it may seem at the time , when I have it apart and make a note. I have already been caught out by different sized items e.g clutch hub nut, fork top nuts and steering head nut as compared to my Sport.
Still a 350 one will give me something to work on unless a larger type ever turns up.
My plastic actual flowerpot did fit well with the end cut off.It just seemed ridiculous so did not proceed.
Vitesse
Re: Flowerpot
Post by Vitesse »
3potjohn wrote: 13 Feb 2022 22:23 Hi Steve
That will qualify as going in disguise!
