Decent front disc anyone
Posted: 10 Feb 2020 15:44
by Stubaker58
Has anyone got a decent front disc for a 31/2 Sport. Mine have seen better days. If anyone has one it would save me getting mine skimmed.
Stu
Re: Decent front disc anyone
Posted: 11 Feb 2020 16:31
by Richard
I would be wary of having a Morini disc skimmed if I were you. I bought my K2 which had skimmed discs and it was awful to ride. Felt like they were badly warped, so bad that I only did short test runs. Checked run-out and it was OK. Think the problem was skimming warped chromed discs takes the chrome off the high spots and leaves chrome on the low spots with consequent changes in friction as the pads contact the revolving disc. Might have thinned out the disc too much if chrome removed from low spots as well. Have experienced warped discs on bikes and cars, but never as bad as that. New discs completely resolved the problem.
Posted: 11 Feb 2020 17:00
by 'It must be a .....'
Hi, get a good engineering shop to grind the discs back to sound surfaces that are flat and parallel to each other, skimming is not the solution and leaves the fluctuations in thickness as described, making the discs scrap.
Posted: 11 Feb 2020 18:11
by Stubaker58
Hi
I was planning to use the “Disc Doctor” as he seems to do a good job, £75 per disc, worth it if they get sorted though.
Posted: 11 Feb 2020 18:40
by Steve Brown
Stubaker58 wrote:Hi
I sent three discs to him a year or two ago and was very pleased with the results. All three were warped/pulsing and rough looking. They came back looking like new and perfectly straight. New pads and great brakes again!
There is also Roy Theresby making discs to fit Morinis now. New so not so cheap as a refurb but if yours are beyond redemption they are well worth a look.
