SORTED Fly Screen Cupolino Morini Kanguro Camel X3 SORTED
Posted: 01 Oct 2018 09:57
by Tom
I know it's ugly, but i am looking for the little fly screen that goes on top of the little fairing of the X3 Morini Enduro's
I want to built my 501 into the best touring machine ever ....
Must be in good condition please.
Other Morini parts available for trading ...
tomros@live.nl
The Netherlands
Re: Fly Screen Cupolino Morini Kanguro Camel X3
Posted: 01 Oct 2018 22:42
by 'It must be a .....'
Hi Tom, your 501 Camel looks great. I found the larger screen wasn't much fun at higher speeds due to turbulence and the bike was far better to ride without it.
The previous owner thought the same; we are both tall which may make a difference?
Good luck with the quest, Ian
Posted: 02 Oct 2018 09:27
by Tom
Hello Ian, thx for that, as you have given me some good ideas/ Camel advises before, i will trust on you!
Also will contact somebody who has both the XE and X3 Camel, so he can compare both situations.
I am 1m 76 cm's, more of a Italian sized Dutchmen (the Roman's also entered these low swampy lands did you know) ,so less prone to have the turbulence on and over my head, but i know that my brother ( over 1m 83cm) had the same issue's with his Moto Guzzi Quota.
The solution was to / or/ mount a fairly big screen which he could tuck behind/ or / get rid of the standard in between sized screen, do without it and deal with the less turbulance it created.
Tom
Posted: 04 Oct 2018 08:40
by Tom
Hmmm, been in contact with the XE & X3 owner, seems to be the only sad truth..
Will write it off the list then..
Sorted.
Re: SORTED Fly Screen Cupolino Morini Kanguro Camel X3 SORTE
Posted: 04 Oct 2018 09:24
by Haboola72
Hello Tom,
on another subject.
Do you have some x3 tank shrouds in good condition? I'm patching mine but would prefer some good ones!
Great looking bike.
Pete
Posted: 07 Oct 2018 08:37
by Tom
Hi Pete,
Thanks!
Shrouds? My guess is that they are the nylon strips/ bands that go over/ protect the tank's edge's?
Wild quess is that you will have to find somebody who's selling X3 parts on for example Ebay.it / subito.it and/or get some (auto) material that can replace it, like the strips they use on the inside of car doors?
Kind Regards,
Tom
Posted: 07 Oct 2018 19:36
by Haboola72
Thanks for the reply Tom,
by 'shrouds' I mean the black pressed plastic covers either side of the headstock, they are fragile and lead a hard life!
The strips you mention are available through car trimming suppliers.
many thanks
Pete
Posted: 07 Oct 2018 20:03
by Ming
Haboola72 wrote:Thanks for the reply Tom,
by 'shrouds' I mean the black pressed plastic covers either side of the headstock...Pete
I think they are supposed to look like radiator shrouds.
Posted: 11 Oct 2018 07:15
by Tom
Ahh, yes....
Well, found mine in Italy on Subito.it
But since they are so fragile, people from the German Morini Club suppose that you should make them out of a plate of rubber. For that you will need the real one's in order to copy them into rubber.
There was a nice 'how to' turorial on the La Strega website, but since it had a crash a while back, everything there between beginning of 2018 and 2014 has been erased!
a sort of Morini Tsunami
