Mk 1 Camel and X3 Kanguro parts wanted
Posted: 17 Jun 2016 21:53
Hi Chaps,
Looking for the black plastic speedo cowl for a Mk1 Camel, have got the small headlamp, looking to add a bit more originality to the bike. Not sure if they were fitted to later twin shock Camels but consists of a speedo holder on the right with idiot lights on the left and follows the shape of the top of the 6" rubber cased headlamp.
Also, as fitted to the X3 Kanguro, a front brake lever and master cylinder assembly, the type I'm looking for has an adjuster on the piston push rod.
These may also be fitted to other Morinis, I want one to use with a single disc. My current set up ( not on a Kanguro) has Brembo lever/ cylinder but no adjustment on the lever and is just a bit to far from the bar for a comfortable reach. The brake set up on my Kanguro is fine so I want to fit one of these.
If anyone can help, please pm me with cost and postage.
Cheers, Derek
Cheers, Derek
