Later switchgear
Posted: 09 Apr 2016 09:15
by MickeyMoto
Anybody got any later switches, please?
I mean the Dart/Excalibur/New York type, although a complete set of the earlier CEV may be acceptable if it has a starter button.
thank you,
Mike
Re: Later switchgear
Posted: 09 Apr 2016 12:29
by morini_tom
What exactly are you after it for, as the Excalibur/New York switchgear is different to the dart's (it's from the same range but dart's brake master cylinder bolts into the throttle switchgear casting, and clutch lever pivot is part of left switchgear, whereas NY/excal have brake master cylinder and clutch levers on separate clamp onto bars parts from the switchgear)
I've probably got a spare set of used dart switchgear
Tom
Posted: 09 Apr 2016 20:18
by MickeyMoto
Hi Tom,
Haven't seen a Dart for a while. I just want more modern switches for my Strada. I know the later Kokusan engines have the kill switch reversed. Open circuit cuts the engine instead of open circuit to allow to run on the earlier Ducati bikes.
Looks like the Dart switches are not suitable. Thank you for responding.
Posted: 09 Apr 2016 20:37
by hombre
I might have one from an Excalibur, I'll check for it tomorrow...
Posted: 17 Apr 2016 16:15
by hombre
Tomorrow turned out a bit later... sorry 'bout that :oops:
But how many do you need? :-)
Posted: 17 Apr 2016 16:39
by MickeyMoto
No worries. Ground to a halt anyway as apparently I'm supposed to be doing some decorating she remembered I told her in 1992!!
Just one of each is sufficient.
Thank you.
