WTB: Pair of transducers (black) for 350K2
Posted: 16 May 2015 16:22
by AntietamClassicCycle
Ground wires have rotted off of a customer's 350K2 transducers, not even a stub left to splice a wire onto. Anyone have a good pair for sale?
Re: WTB: Pair of transducers (black) for 350K2
Posted: 16 May 2015 20:28
by Ming
I seem to recall that the white (Bianco) connection on the transducer is also an earth - can you use that? (Or am I mistaken?)
Posted: 16 May 2015 23:59
by norbert
That´s true, i would give it a try
Posted: 18 May 2015 06:41
by hendre
AntietamClassicCycle wrote:Ground wires have rotted off of a customer's 350K2 transducers, not even a stub left to splice a wire onto. Anyone have a good pair for sale?
I'll have a look in my stock tonight
Posted: 18 May 2015 14:37
by EVguru
Yes, the white wire terminal is internally connected to earth.
Posted: 18 May 2015 18:44
The wire that has "rotted off" is the potted in white(?) ground wire. The transducer needs that to function, correct?
Posted: 18 May 2015 18:58
by EVguru
The potted in wire with a ring terminal on the end was an earth and would have been blue or at least blue-ish originally.
The 'Bianco' terminal is also an earth terminal and you can simply run a wire from there to the earth bolt.
Posted: 18 May 2015 19:28
Thanks! Will try that.
Here's the rotted off bit:
by norbert
Exactly!
Normaly the two white terminals are conected to avoid earth-problems in case that one of the original blue (or brown) earth-wires is out of order.
Posted: 18 May 2015 19:50
Great! Thanks guys. The customer will be happy that I may not have to spend all of his money on the ignition.
Posted: 18 May 2015 23:49
Won't be needing the transducers after all. Made little "Y" harnesses to connect the white terminals to the ground and it now has bright blue sparks!
Thanks to all that responded.
