As in the description i need a carb body for 1975 morini 3 1/2 sport, snapped the idle screw in and extractors wont see it out.
Matt
Dellorto VHB25bs carb body
Morinimatt
FatherB
Re: Dellorto VHB25bs carb body
Hi Matt, make sure it's from a 4 stroke. Lots of VHB 25BS are around as fitted to Benelli/Guzzi 250 2 stroke twins. They look identical but have different internal drillings which really throw off the mid range carburation.
Morinimatt
Will do thankyou, is it obvious in a side to side comparison? I have found one on ebay however its a complete unit and no pictures of internals
I might have a couple, but of a later model, so with breather tubes etc. If you are not after the original looks they might be of help?
Hi Matt,
ive got one or two complete here in the UK if you want. (Bath)
Simon
tel: 07788 442155
Simon
tel: 07788 442155
ianlucas006
Hi Matt
Almost certainly got one. Will have a look tomorrow if the flu lurgy has abated a bit! Thanks Ian
