Brake caliper top bolt and spacer
- Parker3865
I assume the stepped bolt for the top mounting of the front brake caliper is the same across all models? I need the bolt and the spacer, with nut if possible. Many thanks Richard.
Morini 250 2c currently rebuilding from a box of bits.
Re: Brake caliper top bolt and spacer
Hello Richard
I may have one. In France at the moment but back to UK Thursday. Will have a look then.
Thanks Ian
Thanks Ian
- Parker3865
Brilliant, thanks
Hello Richard
Is this what you want?
- 20240225_194434.jpg (489.71 KiB) Viewed 1210 times
- Parker3865
Exactly what I need! Let me know if you are able to post it and how much.
I sent you an email in case it has disappeared in your spam folder. Thanks Ian
I also require the same components, or at least the bolt if anyone has one available.
Thanks Robin
Thanks Robin
I supose yor calipers from a 500 SEI are the ones with the plastic cap. The spacers for this triangle calipers have a thickness of 4mm on the upper bolt.
Thanks Norbert, the front calipers are the triangle ones. They don't have a plastic cap across the top. (edited as the penny has dropped after a coffee!)
