The Morini 500 with the 5 charging coils has two wires coming out (as discussed with Westcounty Windings this was all I that is needed). At 5000 rpm the stator is putting out about 60 volts AC from the two wires coming from the stator coils.
I just bought a new Ducati 2 wire reg/rec from Mdina Italy and hooked it up as I figure is correct: the two wires from the stator (my stator has one yellow and one red from the coils) connected to the two G terminals on the reg/rec. A brown jumper wire from reg/rec R+B terminal to fuse box brown wire terminal and a ground wire from the reg/rec body to engine ground.
I am not getting anything above the 12.4 volts of the fully charged battery at idle or up to 5000 rpm. So in effect I am not getting anything out of the reg/rec in DC voltage.
I must have something not connected properly, any help much appreciated
