500 sport sei-v (1982)
Posted: 15 Mar 2025 12:59
Hi everyone,
I am selling a 1982 500 sport sei-v that is currently in France (Paris) but has English papers (registered as a historic vehicle). It comes from Spain (Cataluña) and I have pretty much no info on its long life, sorry. I am selling as I have a small garage and need room for another project (also I have two other 500 in house
It is mostly original, without starter motor though. Here are some infos:
- the frame and engine numbers match.
- the Lafranconi mufflers are in perfect shape.
- the tires and tubes are new (Battlax BT46)
- the brake calipers, front and rear, were given a proper clean and work perfectly, with new brake lines and new front pads.
- it has a Brembo front master cylinder but I can swap it with an original 19mm Grimeca freshly refurbished if you prefer and a matching clutch lever.
- all lights are working, the horn too.
- the original paint is in good condition overall, but shows its age.
- the carburettors were completely cleaned and reassembled with new o-rings.
- it has an original airbox.
- the meters are not original, as I don't think the 500 came with a mechanical rev counter and so the 12000 km are irrelevant.
- the tank is clean, with its original taps (one electric).
- while recomissioning the bike, I opened the cylinders (low compression) and replaced the piston rings with new ones fom Mdina. Compression is good now, valves cleaned and clearance ajusted.
- new cambelt.
If you are interested, the bike will be brought to Devon, so can be picked up there or on the way. It can also be picked up in France of course! If you have more question, do let me know via PM, I can also send a video of the bike running at idle.
Oh and, almost forget, the asking price is £4200.
Simon
- new cambelt.
Simon
