Indicators
Posted: 29 Apr 2015 08:11
by Clarach44
Hello , My 1974 sport has neither mirror or indicators ! Scary . Mirror easily solved but as an electrical dunce can someone post a very simple diagram to help me wire up some indicators . Modern drivers don't seem to understand hand signals ! Thanks. Peter
Re: Indicators
Posted: 29 Apr 2015 10:51
by EVguru
The first problem on an early bike with the "snuffbox" switchgear is finding room for an indicator switch. Most setups I've seen were so awkward to use that waving your arm is probably easier.
The club bike has been fitted with a modern style combination switch for this reason.
An indicator circuit is quite simple in essence. The usual setup is to have an (ignition) switched feed to a flasher relay. The other side of the flasher relay goes to the indicator switch common terminal. The outputs of the indicator switch go to the indicators themselves, which are wired in parallel and locally earthed to the frame.
The early Morini fuse panel has a spare fuse position for indicators. It needs a wire added to link it to an ignition switched feed.
Re: Indicators
Posted: 29 Apr 2015 13:00
by Clarach44
Thank you , I am surprised to say I understand your explanation. I will search for a neat switch .
Re: Indicators
Posted: 29 Apr 2015 13:24
by Clarach44
Re: Indicators
Posted: 30 Apr 2015 08:03
by MarkB
My Sport's got the snuffbox lightswitch with a separate indicator switch. As the indicator switch is next to the handgrip I find it easy to use. The Strada's got a modern combined light and indicator unit, which is available from Paul Goff.
Re: Indicators
Posted: 30 Apr 2015 17:58
by Clarach44
Thanks Paul. I checked out the Paul Goff site and the solution is there including wiring diagram. Regards Peter
Re: Indicators
Posted: 01 May 2015 13:35
by Ralph
This is the set up on my 76 Strada
Re: Indicators
Posted: 01 May 2015 18:13
by 3potjohn
I had indicators on my 82 bike-but these were not fitted when I got it. I decided not to use these originals as relatively heavy. I did experiment with so called mini-indicators but these use a fairly high wattage bulb (21w I think) and not very visible. in then end I got some from Vehicle Wiring Products, which were cheap,light, easy to fit,easy to replace if you break one off.
More modern switchgear would be useful perhaps?
