Various Morini parts available
Feeling somewhat better, so I ventured into the barn and grabbed the first few bits to hand.
An unused 500 exhaust spanner.
Bearing support for a mechanical tacho.
A pair of Veglia Speedo & Tacho supports, without the rubber gaiters.
A white faced kmh Speedo in good condition.
A cable brake / clutch lever (early singles I think).
A Grimeca front master cylinder, probably in need of new seals.
Sorry the photo is a bit fuzzy, a bit like my vision!
Watch out for the next tranche.
I have a plastic 350 heatshield - the mounting points need repair.An unused 500 exhaust spanner.
Re: Various Morini parts available
I would be interested in the gauges support brackets. Could you email me at rbannister59@gmail.com
I am guessing the normal Sport rubbers would fit ?
Many thanks.
Ross
Many thanks.
Ross
Hello Ming / Ross
The clock supports are actually very early Strada ones. I am looking for a set! If you want Sport ones I probably have some as well as the rubber supports. Thanks Ian
Hi Ian,
I am after a support like this for my sport so I can fit my strada top clamp.
Here's another batch
A 350 battery base rubber.
A gear selector rose joint adaptor.
An iffy black transducer.
A set of pushrods from a Kanguro.
A pair of fork slider caps and cable guides.
A repaired stator mounting plate.
A pair of handlebar levers of unknown provenance.
PM me for an item and I'll set it aside.
So, a front hydraulic hose splitter mount.A 350 battery base rubber.
I’m currently putting together a sectioned engine for the club so am on the lookout for certain parts, and damaged ones are ideal as it saves using bits which would otherwise keep a Morini mobile.
To this end the pickup and stator plate would be perfect please.
The pushrods and gear selector joint would be useful too if someone doesn’t have a greater need
Thanks,
Tom
Thanks,
Tom
A few more parts.
A 350 kickstart mechanism & primary gear
Rectangular Bosch headlight & 350 CEV tail light.
A couple of 350 sprockets, 14 & 16 teeth, plus a 500 / 501 , a ratty exhaust nut, 2 sets of exhaust collets (350), lever end clutch adjuster.A 350 kickstart mechanism & primary gear
And more:
A 350 centre stand, a Kanguro kickstart, a lifting handle, a pair of pillion footrests, a pair of Kanguro footrests.
I know there are a couple of 350 rocker box covers, some Excalibur footrests and other odd bits, will look them out now it's a bit warmer.
The lifting handle will come in handy (if you forgive the pun) please
Thanks,
Tom
Thanks,
Tom
Interested in the cev rear light - will pm you direct
I would be interested in the 500 sprocket! I sent you a PM about it.
Pour Michel3007, je ne peux pas poster des photos par PM, donc:
Je crois c'est pour 500 / 501Re: Various Morini parts available
Apologies - I described the speedo as being a white-faced one. I was mistaken (that went some time back). This is a black-faced speedo, with a nice chrome bezel, calibrated for km, km/h.
Might make your bike look even faster!Re: Various Morini parts available
All of the parts have gone to new homes now, thanks.
