Clutch adjustment
Posted: 03 Jul 2024 08:48
Morning All
Quick question re clutch adjustment. I've set the operating lever at 15.5mm from the crankcase by releasing the locknut and adjusting the screw.
My question is, does the locknut come up firm against the operating lever? Or up firm against the crankcase?
It was up against the crankcase but in this position the lever will move around when the clutch cable doesn't tension it. Is this normal or should the locknut come up firm against the operating lever to make the lever itself firm?
I hope that makes sense!
Martin
Martin
