350 Strada electronic tacho repair
fatblokeabroad
Post by fatblokeabroad »
MOVED FROM ANNOUNCEMENTS
I recently had my electronic tacho repaired by speedy cables ( www.speedycables.com) in Swansea. They replaced the cct board, calibrated and fitted a new bezel that I supplied. The process was not cheap and I am not convinced the tacho is working properly now. I found the bezels on e-bay, they are supposedly for smiths 80mm meters but fit perfectly.
The tacho does not move under 4000 rpm then does not climb above 1000 despite rising revs. All connections appear correct, 12v earth and a signal (not stable ) that changes with revs. further work is required, luckily the engineer at speedy cables is available to chat as required. All work has stopped at present due to a close encounter with a very large dog with a dislike for morinis. I am pleased to report the dog was undamaged unlike my shattered left side tarozzi rearset and a bent exhaust.
