Carb balancing questions
Posted: 12 Feb 2023 12:13
My 81 Strada is ticking over a bit lumpily so I thought time to get the carb balancing kit out
My problem where are the holes to fit the vacuum pipes. I can see a moulding on the intake rubber where I would expect to find vacuum fittings but it's solid rubber there is no cap or plug.
Do I have to drill a hole through the moulding or is there vacuum take offs somewhere else probably behind the rear wheel spindle I am used to Japanese multis and Italy seems to do everything arse about face.
