Grimeca brake caliper piston sizes question.
Posted: 30 Jan 2023 18:16
by Fastmongrel
I have stripped the front Grimeca caliper on my 81 Strada and it was full of brown sludge probably ancient brake fluid. I want to replace the seals and the pistons.
I have found the correct 41mm seal kit at Mdina but the only pistons I can find are 41 x 18mm ones for a GM1 go cart brake. The pistons that came out of the caliper measure 41 x 15.6 mm and the piston hole in the caliper is 16.6mm deep.
Can anyone point me in the right direction for pistons they seem to be in very short supply.
Re: Grimeca brake caliper piston sizes question.
Posted: 30 Jan 2023 21:36
by Fastmongrel
After a good soak in brake cleaner the nasty cack on the pistons I thought was corrosion has come off. Must have been more of the ancient brake fluid, the pistons are actually in really good condition and look like brand new. I will just fit the new seals and hope there's no leaks.
Posted: 19 Apr 2023 10:10
by Neadethal
Great you ended up not needing a solution but i've read and think there is a video that people machine down 18mm pistons to fit from the same kart brake. Hope this helps.
Posted: 16 Jul 2023 13:13
by mikebn
i have had made 40 x16 black anodized cliper pistons they are in the latest copy of club mag
