red light
Posted: 21 Aug 2008 16:27
by dougi
the red light on my 1978 3-1/2 sport stays on when the engine is running. is that ok ? if it is ok why is it on when its running ?
Posted: 21 Aug 2008 17:19
by ringer
Assuming you have checked the connection of the wire on the oil pressure switch, have you tried disconnecting the wire from the switch and measured the resistance of the end of the wire to earth? If the wire is damaged and shorted to earth then that would result in your symptoms. Otherwise buy yourself a new oil pressure switch - compared to a trashed engine it is much cheaper and easier to fit.
Nick
Posted: 21 Aug 2008 20:05
by dougi
i have,nt checked the wiring yet. i did,nt think morini 3-1/2s had oil pressure switches ?. i am now thinking it is to do with the battery charging system,when the red light is on it is not charging the battery?
Posted: 21 Aug 2008 23:12
by ringer
All combustion engines should have an oil pressure switch. There is an electrical circuit which starts with 12V sourced from the battery, connected through the red idiot light, along a wire that goes down the front left-hand tube of the frame and to the oil pressure switch which is located on the underside of the LH crankcase cover near the front. When there is no oil pressure - i.e. no oil being pumped around - this switch creates a connection to earth which completes the circuit and so the red light comes on.
In this picture, follow the wire that goes down to the bottom of the front tube of the frame and then back up slightly underneath the LH crankcase cover. That is where the switch is, where the wire is connected.
When you first switch on the ignition the engine is not working and so there is no pressure in the oilways. Hence the red light is on because the light is connected to earth. When you start the engine and it is running, the oil pump pumps the oil through the oilways and past the pressure switch which detects this pressure and stops the connection to earth which breaks the circuit and the red light goes out.
If your engine is running and the red light is on THIS INDICATES A BIG PROBLEM. Either there is insufficient oil in the engine or you have an electrical problem with the wiring to the pressure switch. Have you checked the oil level or condition of the oil in the engine recently? Whatever your answer DO NOT RUN YOUR ENGINE until you have established why the red light stays on.
Posted: 22 Aug 2008 06:17
by hendre
have to agree with dougi.... early Morini's did not have a oil pressure switch. The red light indeed had something to do with the charging circuit.
Posted: 22 Aug 2008 07:25
by George 350
Red light:
Prior to the electric start models, there was no oil pressure switch on Morini's - I recall it was introduced with the 500 in 1978 (4 warning lights), and then on the 350's later.
On non electric start models this light simply served notice that you had turned the ignition on (as if the clunk of the fuel tap didn't tell you that). If it went off, either the battery was flat or it had blown.
If it annoys you, simply take the bulb out (or wait for it to expire).
When I rebuilt mine 10 years ago I made up a new wiring loom from sctatch and I modified the circuit so that the light became a charge warning light - on = no charge, off = all ok.
Re:
Posted: 06 Jul 2020 20:01
by Vitesse
George 350 wrote:Red light:
If I'd done my search first I wouldn't have had to ask you George!!!!!
