Morini 350 K1 dynamo/regulator wiring
Posted: 25 May 2019 19:10
by Tim Louth
Hi all, I need a little input on the dynamo wiring on my 350 Sport K1. I had a bit of paper with important stuff written on it but it has disappeared. Touch of the seniles I think. There are 5 wires coming out of the dynamo, Red, Green, White, Yellow, Yellow. On the regulator there are 5 connections, G, G, R, +B, C. I can't find a wiring diagram that shows this set up with 5 connections on the regulator. Does anyone out there have a K1 that they can check the regulator and dynamo connections for me. Many thanks.
Re: Morini 350 K1 dynamo/regulator wiring
Posted: 25 May 2019 20:44
by EVguru
The 'RED' terminal on the regulator has no internal connection, it's just a connection point. I think it's only used on the 250 2C, which doesn't have a fuse panel. The white wire is an additional earth, it goes via the fuse panel to terminals on the transducers.
Posted: 25 May 2019 21:11
by Tim Louth
Thank you Paul. Is the B+ just a straight wire from the battery positive?
