Help!!! Morini wont start!!!
Posted: 22 Feb 2017 14:43
by kellytg
HI all!
i try to start my morini 501 but he cant start.I set up belt on marks,i set valve,i watch video on yt about paul how to put pick up so i put it like he show on video but nothing morini wont start,only sometimes fire from exhaust.when i turn pickup on aonther side morini kick back and he almost start;
what i need to do now i do all like shows in manual and in videos but nothing,only when i turn pickup on another side he almost start.
someone please help i need to start him allready
Re: Help!!! Morini wont start!!!
Posted: 23 Feb 2017 10:43
by Bison
Was it running before you replaced the belt?
Posted: 24 Feb 2017 15:05
by kellytg
yes!
Posted: 24 Feb 2017 16:38
by MickeyMoto
Is the belt out by 180 degrees? If you bring the front cylinder to TDC on the compression stroke (both valves closed) the timing mark on the camshaft pulley should be at the bottom out of view, not at the top. Well, mine is and it starts.
Posted: 25 Feb 2017 16:49
by Bison
Like Mickeymoto says, TDC on the front cylinder, valves closed.
Hope you get it going.
Alan.
Posted: 26 Feb 2017 22:38
by kellytg
i do all what you say but still doesnt start! any idea
Posted: 27 Feb 2017 08:22
by MickeyMoto
Please and thank you is a good start.
So, belt correct. Timing marks set for static timing - knobbly bit of flywheel in centre of pickup with timing marks lined up.
Both coils have power. Spark at plug when kicked. Carbs clean.
If all set then it will start without kicking back.
Are you an MRC member? If so you can download the later engine manual.
Posted: 27 Feb 2017 20:47
by Ming
[quote="MickeyMoto"]Please and thank you is a good start.
Can you say that in Bosnian, please?
Posted: 27 Feb 2017 21:17
by MickeyMoto
Ming wrote:MickeyMoto wrote:Please and thank you is a good start.
molim i hvala. !!
Posted: 28 Feb 2017 23:42
by kellytg
can someone of you make some video of instuctions or does someone of you have viber or whatsapp to help me more about this problem
Posted: 01 Mar 2017 08:13
by Ming
Have a look at EVguru's videos on youtube. That might help.
https://www.youtube.com/user/EVguru/videos
Posted: 01 Mar 2017 08:54
by Archie Adv
Dobro jutro Kelly,
As mentioned previously try what Paul Compton advise me! See below.
When I have a bike turn up with no spark, I break it down to the most basic setup.
Pull all green wires from the fuse panel.
Connect the green wire from the alternator directly to the ignition boxes.
Sretno
Archie
Posted: 01 Mar 2017 19:41
by MickeyMoto
Hello,
I think I misread this. Is it Ducati or Kokusan ignition?
Posted: 01 Mar 2017 23:14
by kellytg
Ducati!
Posted: 02 Mar 2017 07:42
by MickeyMoto
ah, OK. Was thinking it was Kokusan. Have you checked the trigger wires are going to the correct transducers?
