Just a few questions before I start seriously looking to buy.
Unleaded or leaded petrol?
What is the spares availability like?
Where do you buy your cambelts?
Before I take the Plunge
- George 350
Re: Before I take the Plunge
Hi Papa,
In answer to your questions;
I've run mine on normal unleaded for ages, but since the ethanol issues, I've been choosing the high octane stuff that doesn't say EN228 on the pump, Not a brand snob, but the local garage is a Shell one. (allegedly ethanol free for most of the country)
North Leicester Motorcycles have a very good supply of almost everything you will need.
parts prices reflect their low volume production levels, ie. they can seem expensive when compared to popular British classics or Japanese ones come to that, but equally they are relatively cheap if you look at the price of some modern bike stuff.
The very good news is that unless you are unlucky, you won't need too many of them!
There are several bikes in the club with 100,000 miles or more on them - my Sport is a junior at just 98,000 miles from new.
Many people will use NLM as an easy peace of mind choice, but the belt is a standard 'industrial' belt and they are available from many places.
The original factory ones were (are?) made by Pirelli, and were graded to reflect tolerance build up in the pinion/centre distances but as long as you use a reputable/known make you should be OK. Worst thing about buying 'off the shelf' belts is that they can have a wide tolerance, so it may take 2 or 3 belts to find one that is the proper fit.
I run Conti belts, purchased through RS components and have been 'lucky' in that they have all been good as fitted.
Belt changes should be done at intervals of 12000 miles or 2 years.
Hope that this helps,
George.
George.
Papa Lazarou
it does, thanks.
To put it in perspective, I am looking to get a Moto Guzzi V65 Lario. Many parts for the Lario are more difficult to find than for the Morini. I think the difference is that there is a closer Moto Morini community than many other marques and also because Morinis are very reliable once set up properly.Papa Lazarou wrote:What is the spares availability like?
HTH
Vrrooom!
you're a brave guy, i have been running a lario as daily transport for a couple of years, but wouldn't recommend them.To put it in perspective, I am looking to get a Moto Guzzi V65 Lario. Many parts for the Lario are more difficult to find than for the Morini.
most of the rumours about dropping valves and chocolate camshafts are actually true...
having said that, they are fun as long as they run.
Papa Lazarou
Always get the big block Guzzis.
