Carb Float Removal
Posted: 02 Dec 2007 17:41
by Gruff
Hi I have stripped my carbs (VHBZ 25 HS) for cleaning and want to remove the floats. Does the pin holding the floats unscrew or just pull straight out, I have had a quick tug but dont want to damage the pin. Please help
gareth
Posted: 02 Dec 2007 19:43
by robinh44
Gareth
It should just tap out, on mine I gripped the end of the pin with some long nose pliers and then gently tapped the pliers body until the pin came out.
Robin
Posted: 03 Dec 2007 13:11
by Gruff
Yep that worked, thanks Robin.
I have stripped the carbs ok but some of the gaskets and seals are a bit tired, where is the best (cheapest) place to get them. Thanks
Posted: 03 Dec 2007 14:47
by robinh44
Gareth
If you mean the float bowl o-ring, if you are very careful you can get away with a very light smear of silicon sealant. You must use only a light smear otherwise the silicon can squish inside and stop the float moving. Not that it has happened to me, some bloke told me in a pub honest
Robin
Silicon and carbs
Posted: 03 Dec 2007 15:40
by George 350
Please! NEVER use silicon sealant on carburettors, or anywhere else that comes into contact with petrol. Petrol will attack it, little bits then break off and either block up your jets or have an amazing tendency to find their way into the small drillings within the carb body, or both. Use new o-rings and gaskets - they are only pence each, and you shouldn't have problems. If you do, then your carbs are probably knackered.
NLM and Contact Developments (Dell Orto importer/concessionaire) sell carb rebuild gasket sets.
Posted: 03 Dec 2007 20:32
by robinh44
Hi
George is right of course, silicon sealant turns to a nasty gooey mess, for silicon in my post please read as hylomar which is petrol resistant. Again a thin film can get you out of trouble, a new o-ring is always better, but if you have'nt got one late on a Sunday getting the bike ready for the next week of running it can get you out of trouble.
Robin
Posted: 04 Dec 2007 00:21
by Gruff
Thanks Robin, George; I need to order some stuff from NLM anyway so I will stick the carb kit on the list.
Posted: 22 Dec 2007 21:33
by Jem
Dell Orto UK are very helpful and their prices are very good. Buy service kits from them and, while you're at it, if you have the old black floats buy the new white precision cast floats. These solved a long standing problem with starting my Sport.
