Clutch center nut
bobajob
Clutch center nut
Post by bobajob »
Any advice on the easiest way to remove the clutch centre nut? I don't have an impact driver of the special tool so assume I'm going to need to acquire one of these. I want to remove the entire engine cover so I can get it painted.
thanks
Bob
bobajob
Re: Clutch center nut
Post by bobajob »
will sos need to replace the oil seal as the rear plates had oil on them. The clutch plates were in a terrible state with the friction lining material falling off the plates. Amazed it worked.
The clutch hub holding tool is a couple of old steel clutch plates with a handle.
For the small extra cost I'd always replace all the plates, not just the friction, so you end up with plenty of plates to make the tool.
See my clutch rebuild series;
http://www.youtube.com/playlist?list=PL ... mMpvHxFJ38
bobajob
Post by bobajob »
Paul,
Videos are brilliant, just wish I'd seen them before I'd stared. I've managed to knacker one of the clutch inner studs. I've go a replacement stud on the way from NLM and a friendly machine shop so should be able to salvage it.
Rob
Clutch stud removal the easy way;
http://youtu.be/jVN1_Iijy-8
bobajob
Post by bobajob »
good information, explains why I don't have threaded studs, the engine is from a Kanguro.
