500 Heads
SoloFrenos
500 Heads
Post by SoloFrenos »
I am toying with the idea of fitting 500 heads to my 350 (well actually it will be 375 in a few days when i get the barrels etc back from the engineers) but i am i'm right in thinking that the exhaust flanges are different on the 350s and 500s. Is that right? If so is there a simple solution for fitting the 350 downpipes onto 500 heads?
Re: 500 Heads
SoloFrenos wrote: is there a simple solution for fitting the 350 downpipes onto 500 heads?
Yes.
SoloFrenos
Re: 500 Heads
Great thank you.
oh by the way, what is the solution exactly? :D
hendre
Re: 500 Heads
Post by hendre »
flanges are identical, pipes are thicker after about 2 inches and inside diameter for the nuts is larger... that's it. :mrgreen:
mgill
Re: 500 Heads
Post by mgill »
The heads won't fit though. The intake valve is too close to the barrel wall
iirc. Was told by Stuart at NLM. I've never tried.
MRC #2795
Re: 500 Heads
mgill wrote:The heads won't fit though. The intake valve is too close to the barrel wall
They definitely will fit on a 400 bore. Havnen't checked the 375. Bengy used to put them on stock 350 bores and relieve the cylinder wall at the top.
SoloFrenos wrote:oh by the way, what is the solution exactly?
Custom collets.
SoloFrenos
Re: 500 Heads
Hmm, in recent emails to Stuart about my ideas he did not say that the 500 barrels would not fit, maybe i should just check with him (or have a look when my barrels come back) He did suggest the NLM pick-up mod is a good 'tuning ' aid. So maybe i should sell my 500 heads and buy one of those!!
