Flywheel questions
Tom
Flywheel questions
Post by Tom »
Hi morinisti di Angleterre
I have a question for you:
Are flywheels of different morini models interchangable?
I am asking because i have a charging problem with my 3 1/2 sport from 1977, the alternator has been rebuilt and worked OK, even with a 60/65 watts Halogen head lighted installed i now know, oeps.
But since this summer I am having recharging problems during long trips. The other day when i made a short trip (35 km back and forth) the battery was fully charged, last week i came back from a 150 km trip, the battery was fully flat. So i swapped the regulator, checked all the earth connections and wiring, and noticed a melted connection on the red and brown wire at the ignition switch. Any clues?
I now swapped the flywheel, to check if it is magnet problem, for a item from a kanguro or camel, they look the same and fit OK, is this advisable?
Best Regards,
Tom
Re: Flywheel questions
There is an early narrow flywheel with fully machined finish and flush magnets and a later wider type with cast finish and salient poles (with or without starter drum).
The narrow type may foul a wide stator and damage it.
The brown wire is the feed from the ignition switch that turns the regulator on.
Tom
Post by Tom »
Thanks again!
It could also be the faulty connection of the brown and red wiring at the ignition switch due to an earlier problem with a faulty battery which fried my old altenator, hence the rebuilding of it...
So restoring the wiring could simply solve my charging, eh the morini charching problems... hopefully
Tom
