Brake Master Cylinder help
The front brake is poor on my '76 3 1/2 disc braked Strada.
There appears to be a jet of fluid coming back through the small port, back into the brake fluid master cyclinder reservoir. This occurs all the way through the brake level travel.
I suspect the master cylinder seal has gone.
a) Any advice or diagnosis welcomed.
b) Has anyone any experience of repairing master cylinders? I will ask NLM is theye have a seal kit.
(I've replaced seals on car master cylinders but I've never done a bike one.
Thanks, Craig
Thanks, Craig
Well not much use to report I did a K75 one a few months ago by fitting a new seal kit. My Morini will not be needing it's brakes for a while.I have the engine to pieces now. Something unpleasant has happened to various surfaces where oil should have kept them apart.
Actually the brakes were one of the few bits that worked well.However after removing the bleed nipples (hey they didn't round off it must have been a good day) One had slight corrosion and would not seal again properly until I cleaned it up carefully. I expect there was some muck in the calliper too.
NLM do a complete piston assemby for less than a tenner which takes all the stress out of the job.
If you're only running one front disc, then consider spending £50 on a new 250 mastercyclinder, it does wonders for the feel. The original 350 cylinder is perfect for twin front discs.
...moving to a 250 master cylinder
Guys,
Thanks for that advice.
I aim to take the master cylinder apart tonight to see if it is serviceable.
If not then that make the decision to go to a 250 cylider even more of a no-brainer.
Craig
Craig
Well, the master cylinder bore looks ok.
I will talk to NLM tomorrow re: either a new piston assembly or a new master cylinder.
The piston diameter is 16mm. If anyone has details on brake components can you let me know. It would be useful to know if this is a standard master cylinder off a 350. I assume that the 250 and the 350 have different diameter pistons and that gives different braking effects.
Detailed question, I know....!
My bike was a 76 single disc/spoke wheel Strada but made to look like a Sport so could be built out of all sorts of bits....
Craig,
UK
Craig,
UK
No, couldn't possibly be me, I've never really got the hang of selling bikes.
That would proably be why I've got two 250's, three Sports (well, two and most of one in bits), two Darts, a '66 Corsaro, a 501 engined Valentini replica, a Motobi Tornado, a couple of Freccias, and shortly to come a WD BSA B40.
I seem to have run out of space.
