Quick Clutch Question
Having stripped and cleaned the clutch plates and replaced the thrust washer I have a question about the retaining nut washer. The washer has the four pins that locate OK, do I need to bend the washer to sit against one of the nut flats once its been torque up ?
Re: Quick Clutch Question
My old Harglo service manual says during disassembly "...knock back the overturned locking washer .." before undoing the clutch centre nut and then "Always use new lockwasher on re-assembly and recheck sealed nut". The engine strip link from the NLM site also says "first knock down the locking tab washer" (on page 7 here http://www.northleicestermotorcycles.co ... 0strip.pdf. So looks like it should certainly be bent up.
Thanks for the advice, will complete the job this weekend.
