Converting left shift to right for Tarozzi rearsets
Posted: 29 Sep 2010 15:59
Greetings to all...first post here. I recently picked up a '79 Morini 3.5 sport, with the left-side shifter retrofit on it for the North American market. Picked up Tarozzi rearsets to install on the bike, and realized that they're obviously made for the Euro set-up.
So, first order of business for me is to figure out exactly what the right-to-left shifter conversion entails, so that I can effectively "de-retrofit" the bike.
The bike...
The shifter-crossover mechanism under the cases...
The right-side shift linkage hidden beneath the right cover...
Close-up of the left-side shifter set-up...
Looks like I have to remove the original pegs plus the crossover linkage below the cases, then install the left-side brake rearset with a new, shorter brake cable and kicker extender. Then remove the right-side shift setup and insert the rearset's longer shifter rod in place of the current shorter version.
Anyone on the forum had recent experience with de-retrofitting this type of set-up?
Thoughts, ideas, suggestions welcome. Cheers.
Peter
The bike...
Peter
