Chain and sprockets
Re: Chain and sprockets
The diameter of the 6 holes for the bolts in these 6 hole sprocket supplied by Dieter are 1 mm minor than what we need to fix the sprocket to the spocket carrier of the Strada. You have to drill them 1 mm wider (if I remember it well).
rossguzzi
Post by rossguzzi »
Ahh, thanks. Wasnt sure if you meant the centre hole.
Cheers.
jcmarcos
Post by jcmarcos »
norbert wrote: 07 Aug 2025 22:15 The diameter of the 6 holes for the bolts in these 6 hole sprocket supplied by Dieter are 1 mm minor than what we need to fix the sprocket to the spocket carrier of the Strada. You have to drill them 1 mm wider (if I remember it well).
Amazingly, the 36 tooth sprocket that MJCorse made for my Dart has exactly the same problem. It's made in duraluminium, so it might be easier to enlarge them with a round file... I say "might" because I didn't do it, and bolted it immediately on the wheel, having a heck of a tough time and, hopefully not, an abuse of the wheel threads
jcmarcos
Post by jcmarcos »
rossguzzi wrote: 03 Aug 2025 23:59 Mdina stock 38, but I dont see 39. Where in Spain did you get your 39 ?
Alicante based MJCorse did a 36 for my Dart:
https://mjcorse.com/es/corona-mj-a-medida.html
Easy because they make sprockets for Cagiva Freccia, from 36 up to an stupid 54 :lol:
https://mjcorse.com/es/corona-pinon/cor ... 87-92.html
