Cambelt change
gra120466
Re: Cambelt change
Post by gra120466 »
Daddy Dom wrote:When you get to the belt, you can slit it lengthways and peel it off one half at a time without disturbing the timing. Slide the new one on while one half is still in position then remove that second half. Works a treat, I did it last time.
DD
Thanks,
I didn't do that but wished I had as was hard work getting the old one off and the new one off!
Graham
gra120466
Re: Cambelt change
Post by gra120466 »
Mark wrote:Hi Ming.
For what it’s worth I made a flywheel holding tool out of a redundant piece of 18mm mdf by cutting the shape out with a jig saw and fitting 8mm (I think) bolts for the pins.
It’s done 10 belt changes so far with no problems.
Nothing wrong with a bodge if it works!
This is the route I took and made my own version which just about did the trick!
Thanks Graham
gra120466
Re: Cambelt change
Post by gra120466 »
Thanks agin all.
Took me ages but got there is the end. Took me ages but it was really mucky in there so took some time to have a good clean up. Was hard work getting the old belt off and new one on as I should have split the old one as some folks mentioned but hey ho next time will be easier!
All the best,
Graham
Re: Cambelt change
First time in a long time is often like that - be easier next time.
