can anybody explain the two types?
All depends on what is in your engine now... you can easily see the difference in the top part. I would go for later type rods if they are already in your engine just in case the belt brakes...spub wrote:Very helpful Hendre, thanks. I assume you meant 180mm rather than 18.5mm, which would be a very short pushrod, indeed....Doe this mean we have a "short" pushrod of 180mm, another "short" rod of 181.5mm which is also a "long" rod if used with the 180mm rod, and a "longest" rod of 183mm, which I assume is always used on the back??? Or is Morini trying to compensate for variations in valve seat depth, gasket thickness, and rocker/cam lobe wear??? I guess I'll find out when I get the two "short" rods from Stuart at NLM....
