Hi, I'm about to strip the clutch and wondered if there is a tool, like a large slotted screwdriver to undo the clutch springs?
I know I can do it with a pair of clamped screwdrivers but do folks have better ways?
Simon
clutch spring tool
Re: clutch spring tool
Hi Simon,
Make a tool like a large slotted screwdriver, easy peasy
If you want to remove the drum you need another tool to hold the clutch drum to allow you to loose the center nut also make-able if you have a workshop
Hi Simon
I use a BSA/Triumph clutch tool. Readily available on Ebay.
Best regards
Best regards
Perfect! Thanks Mark.
Simon
Simon
