Afternoon
Sorry if this is an obvious one, must the fuel taps always be turned off, even if you’re only stopped for a short while?
I always turn them off when I come home and leave the bike in the garage m, is it still the case if I nip somewhere for a coffee? TIA
1980 Strada
Re: 1980 Strada
I always turn fuel taps off, why wouldn’t you? Coming back to a bike with fuel glugging out from a carb with a stuck float needle scores no points.It is far too expensive to waste.
Re: 1980 Strada
Plus the risk of hydraulic lock and a bent con rod...
The bike should have a solenoid tap, so no need to tinker...![Smile :)](./images/smilies/icon_smile.gif)
Re: 1980 Strada
Thanks both, as I thought-Micky I’ve got the original ‘electronic’ taps but traditional analogue ones are in my bike from previous owner(s)
