Morini wont start helpp pleaseee!!!!
kellytg
Post by kellytg »
Hi im new here i need help my morini wont start!
Electric come on both spark fuel come too but he wont start
He start only on front cylinder... someone have idea what problem is? :(
"Riding a bike is an Art , something you do because feel something inside"
Bikes:
Moto Morini 350 X2
Moto Morini 501 supermoto
Coxey
Re: Morini wont start helpp pleaseee!!!!
Post by Coxey »
Hi Kelly
Have you recently replaced the timing belt? It may be aligned incorrectly i.e. the timing might be out.
Voice of experience! :oops:
Rob
___________________________________________________
1989 Kanguro X3
BMW K100RS
kellytg
Post by kellytg »
belt is changed he is work perfect but now he cant start only on front cylinder something is with eletric
Bikes:
Moto Morini 350 X2
Changed plugs?
Checked leads? May be breaking down.
Cleaned carbs?
Air leak in inlet?
kellytg
Post by kellytg »
i change spark but its the same problem
he work perfectly but one day i take from him generator ant take him on my 501 and i take it back to 350 and he only start on front cylinder...
it is possible to problem is with wires or...green wire have bad connection meaby is that?
Bikes:
Moto Morini 350 X2
penman
Post by penman »
First of all, check for a spark at each plug. If it sparks OK, then you are probably not looking for an ignition fault. If no spark, then read on.
If the last thing you did when it was working was to remove and replace the alternator, then that is the first place to look for a fault. In particular, check the green wire is OK and is on the correct terminal in the junction box. If the yellow or red wires are wrong, it won't prevent the engine starting, though it might prevent the battery from charging.
If all that seems to be OK, connect a volt meter to the green wire on either transducer and kick the engine over. It's difficult to read the voltage this way unless your meter has a "max hold" function, but you should see a reading of 50 volts or more, even if it's only momentary. To make this test, the ignition switch must be on and also the kill switch.
If this test is OK, check that you have put the alternator stator back in exactly the same place as before - not rotated at all. If that's OK, then something strange is going on - start looking for things like broken wires or wires accidentally in contact with the frame somewhere.
To re-state what I said to begin with, double-check the stator, because that's the only thing which has changed. Coincidences can happen, but they are rare!
Good luck!
Joe.
1984 Moto Guzzi V65
1969 Honda CB450
1975 Triumph T160 Trident
2019 BMW F750GS Sport
1978 Morini 500
kellytg
Post by kellytg »
now he only fire on rear cyilinder..it is posible to problem is with carb?
Bikes:
Moto Morini 350 X2
