waterpump
Posted: 11 Apr 2011 18:28
by Bulletje75
Hello
Does anyone of you also have a waterpump which is making a lot of noise? It is working very well, but makes a alot of noise.
Re: waterpump
Posted: 12 Apr 2011 08:33
by morini_tom
I wouldn't say the water pump on my corsaro makes a lot of noise but you certainly know it's there. I asked about this and also the noisy clutch (sounds like a release bearing) at the 6000mile service and was told it was normal.
If you're in any doubt then it doesn't look too hard to pop the waterpumpcover off to check
Re: waterpump
Posted: 13 Apr 2011 09:27
by Bulletje75
The cover is damaged, but not leaking. I'm afraid when I take it of and put it back that it goes leaking.
I dont hear noise from the gear box but realy from the waterpump.
But I onderstand the waterpump makes some noise? Before the morini I had only motorcycles from Japan, so I'm not used of it.
Re: waterpump
Posted: 14 Apr 2011 12:04
by twisty
where is the pump leaking from
Re: waterpump
Posted: 14 Apr 2011 17:45
by Bulletje75
It's not leaking, but making a noise. And I want to know if more Morini's make "this" noise?
Re: waterpump
Posted: 14 Apr 2011 19:32
by twisty
i take it then you've done the old stethoscope trick with a long blade screwdriver to identify the exact place the noise is coming from.
Had a look at the workshop manual and it shows the impeller is on the end of a shaft from the engine.
It's not difficult to remove the water pump cover to have look for play in the shaft (if you've not already done so)
Re: waterpump
Posted: 15 Apr 2011 13:57
by Bulletje75
Today arrived a new cap. So now the mechanic can open the waterpumpcap en replace it. And ofcourse check the impeller. Hopefully the noise will dissapear.
Re: waterpump
Posted: 23 Apr 2011 14:41
by Bulletje75
The new cap is on the bike. The mechanic did not see anything strange and he thinks the sound is very normal for a MotoMorini. So I think I have to believe him.
