de-cat+power commander installed, with pics.
Posted: 01 May 2009 18:01
Well, in total it took 3 hours to install the de-cat, powercommander and sort out a few bits and bobs.
Pics of the bike stripped down
While the bike was like this, I took the time to repalce some bolts/nuts with stainless items as some were quite corroded. also to give it a good clean!
Then the decat went on, however both the mounting points didn't line up so i've just used one like the standard morini pipes...
This is what the de-cat looks like fitted...
Quite a bit better looking than the standard pipework and very nicely made.
After the decat it was the powercommander which took about 10 minutes to fit. I've forgot to take a pic of it however it sits on top of the battery, its tight for space under there now! these pics show where it connects to the injectors and main loom.
This is the bike together....
I've tried to make all the mods discreet, I'm not a fan of anything 'in your face' should we say.
The bikes an 08 veloce with;
carbon front fairing
carbon front fender and spoiler
carbon seat inserts
carbon tank inserts
carbon key surround
carbon hugger
carbon chain guard
black pazzo levers
Gel seats
QD de-cat
power commander
manic motors rear seat cover
i've water proofed the rear indicators and repalced some bolts with stainless items
Need to sort out the suspension properly still and get it set up on a rolling road and remove excess exhaust paste
carbon seat inserts
carbon tank inserts
carbon key surround
carbon hugger
carbon chain guard
black pazzo levers
Gel seats
QD de-cat
power commander
