Headlights
johnwh
Headlights
Post by johnwh »
Hi, I have an early Corsaro veloce and was wondering if someone could help me with an electrical problem with my headlights. Sometime ago I lost the high beam and recently replaced globe, replaced relay, checked the switch block, checked ground and fuses and still no light. When we bridged the relay we have power and light and the relay appears to be switching.
Since putting in and pulling out the relays I now have no lights unless I bridge the relays.
Wondering if the problem is back in the computer and might need some sort of reset etc.
eddydog
Re: Headlights
Post by eddydog »
Hello. check all wires. It happens that the wires inside the braid decompose over time. And contacts are everywhere. On lamps. On the relay. I had a 2006 moto.
johnwh
Re: Headlights
Post by johnwh »
Cheers for the reply. I will check all the wiring again.
