leaking clutch fluid form reservoir - anyone else got one?
Posted: 14 Oct 2008 21:39
by nfitz
I have noticed over the past month or so that the clutch fluid reservoir is weeping at the gasket. I have unscrewed the lid, checked fluid levels and cleaned and replaced to on avail.
I have heard that the actuato (inside the part bolted on the LHD side of the engine/gearbox) may have stuck or not seated propery.
Has anyone else had this problem and found a fix ... is this a waranty item even though ive changes the fluid 6 months back?
Posted: 15 Oct 2008 19:42
by franky
I'd say so..... take it in and get it sorted.
how you getting on sorting your bike out? managed to get all the bits yet?
Hope its getting there
Posted: 15 Oct 2008 20:00
by corsaro chris
Not had this problem and know of no others with it. Definately a claim...
Posted: 15 Oct 2008 20:40
by franky
I've got a crap heavy clutch problem..... when my bike goes for its 1st service again i'm going to get them to sort it.
Posted: 16 Oct 2008 19:40
by nfitz
Franky - I'm still waiting for some replacement MM decals so I can finish of the re-painting and put the bike back together.
I've got the ECU re-maped ready to talk to the PC111 and a plastic pasencer seat to make the bike "single seat " from Maniac Motors.
When the bikes back in 1 pice I have to get it into a MM dealer for its service, upgrades and TPS and CO levels to be re-set and then off to a dyno..
So plenty to do over winter.
Posted: 17 Oct 2008 06:56
by franky
glad its getting there
hope you get your bits through soon.
did you have to get new engine cases in the end?
Posted: 17 Oct 2008 13:34
by nfitz
Slight damage to the clutch cover which I have sandblasted out and had it re-pinted as a colour match.
