Week2, problem 2...
Posted: 01 Jul 2008 21:45
Well I'm into my second week with my Avio and another problem arises albeit considerably more minor than the last one: rear offside indicator has packed up. The bulb's fine and no obvious disconnections but unfortunately I've had to go away to work for 5 weeks so won't be able to check it out until August when I get back
Hopefully it will be easily solved. What I'm more concerned about is the oil that appears to be getting blown across the engine. It's obviously escaping from somewhere but no obvious leaks. Is this normal? I certainly had no similar occurences with my Triumph so I'm guessing not. It's not large quantities, just maybe seeping out somewhere and getting blown back across the engine at speed. Any thoughts on this? It's not causing a problem other than I'm going to have to give it a good clean when I get home
On a slightly more positive note, I've got passed the 5500rpm rev limit in the running in process and was pleasantly surprised at the performance
I love it!!
